New pedal assembly should be here tomorrow. As well as a JVC bluetooth adapter for my headunit.
Kev's '98 Protege Thread
bluetooth is awesome!!!! you'll enjoy that for sure---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
FINALLY!!!!
MFactory in the house!!
Came with the ring gear bolts and also new diff bearings. I guess it's time to learn how to take apart a transmission, eek.
Also got a new brake master cylinder with an outlet for the clutch master cylinder.
There's a "P" above the bottom outlet and an "F" on the front outlet and nothing on the outlet on the other side. Do these markings mean anything important?
Is there a rebuild kit for this Kia transmission? I figured while I've got it apart for the diff swap I'd do a rebuild. It came out of a car with about 72,000 miles. Do I need to do a full rebuild with synchros and all? Or should I just worry about the gaskets for now? I want to do this right, and not half-assed, so please, let me know.
honestly, just put it back together & run GOOD QUALITY fluid. you'll be fine.
btw, glad to see the mfactory diff in house---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
ive never seen a full rebuild kit. but you can get the synchros from mazda still. and most everything else. and there not horribly expensive.you can even get the GTX 3rd gear from mazda still. but thats a bit over $200 alone~PaTricK~
-Current car's-
What are you driving?
Well, that's good.
I do have a question about the MFactory diff bolts, though. They seem short. I haven't gotten all the rivets out of the ring gear yet, but slipping a bolt through one of the holes only gives maybe an eigth of an inch to thread into the diff. That doesn't seem like much. Shouldn't they be a bit longer?
the ring gear is recessed over the diff. so that might be your confusion.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
So the part of the stock diff that holds it to the ring gear is actually thicker than what you can see?
Also, the connector for the reverse sensor has too two pins jumped together already. Did it come like that, or did someone else jump the wires?
Also go this on Friday
It's obviously just sitting there. Needs to be repainted along with the trunk lid. The clearcoat on the trunk is peeling like a bad sunburn. And the spoiler looks like it used to be silver, but was painted white while still on the car.
Sent from my HTC Incredible using Tapatalk.
I've only ever seen the pins jumpedsigpic
96 protege dx - gone :'(
94 Mustang Gt - Became one with a deer
02 dodge 1500 - CAI, random aftermarket exhaust
95 protege dx - now derivable, my new project
Originally posted by firelizardI'm going to go take a bath in $10 bills after my mom makes me a PB&J.
Class mate 1: it wasn't mine, but i think it mighta been a 1 ton and ya it was a diesel
Class mate 2: no way, that truck was way to big to be a 1 ton...
