Well I'd say you pretty much got it, sir, haha. Those indicator lights on the 6 is what I'm changing mine to. I don't like the big box with a blacked out symbol. I prefer the symbol to light up.
Kev's '98 Protege Thread
Says it is. 2000 Mazda 626 2.5L V6 with manual transmission, federal emissions without anti-theft. It's already shipped, so it should be here soon. Also found an engine for ~$695 in PA. Going to email the yard tomorrow to get a better quote and see if there's anything they have that I need.
Sent from my HTC Incredible using Tapatalk.
Just fired off an email to the yard with the engine asking if it's complete or stripped down and if they could send me any photos along with a shipping quote. I also checked rockauto for everything I would need for a rebuild and it doesn't look too bad. I would need a gasket kit, timing belt kit, valves/seals/lifters, etc. I was wondering if there are any high compression pistons made for this engine as well. I think the stock compression is 9.5:1 and wanted to bump that up a little bit, along with shaving the heads of course.
I found some 11.5:1 pistons from http://www.importperformanceparts.net/ for $689 made by Wiseco. That's the only brand with that compression ratio, the highest I saw from others was 10.2:1. I know going with the ZE pistons would probably be cheaper, but I want a little bit more compression. And I don't mind needing to run higher octane gas. If I was ever to buy a car with the SkyActiv-G engine, I would try to get the non-US spec 14:1 compression even if it needs 93 octane, just to be different
P.S. I still haven't gotten an email back about the engine yet. Might have to call sometime, damn.Last edited by irishkev90; 12-16-2011, 12:23 PM.
dont deal with IPP. they are just a middle man. you can order those same pistons from Wiseco directly, and save like $100 bux. unless you like to pay a middle man for taking your order.
pretty much any piston maker out there has the spec's for KL pistons. you just have to actually call them.~PaTricK~
-Current car's-
What are you driving?
Guess what I got today...
Sticker says "00 626 ES 5 speed"
"00 626 V6 5 sp"
KLR9-18881-E
They taped up the connector area, I'm assuming to keep dirt and crap out. It is quite dusty in there, though.
Here's a better picture with the tape off. I was nervous about taking the tape off because I didn't want to tear the label, but it came off perfectly clean.
edit: Typing that part number into Google brings up a couple places to get it from dealers or ECU remanufacturers, none for less than $400 shipped, though.Last edited by irishkev90; 12-19-2011, 08:30 AM.
