how much snow do you have out there right now?
Kev's JDM 1997 Protege
i feel your pain. come on springtime!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
SHE'S ALIVE!!!!!!
Took some convincing, but she finally started up. I let the '98 run for a few minutes to charge the battery as I removed the strutbar and battery tie down. Dragged that out back through ~3' of snow and hooked it to the '97. Turned over a little stronger, but still not enough. What the hell? So I removed the first two spark plugs to reduce the resistance against the starter. It turned over much better this time so I decided to put spark plug one back in to see if it would fire up. She did. So I shut her down, put plug two back in and hoped there was still enough juice to get her going. Fired up just fine that time. I let her run up to operating temp as usual, revved it to about 4,000 rpm, rocked it back and forth a few inches to keep the transmission moving. Everything checked out fine.
I think the reason for not starting was because I skipped it last week because I was busy with other things and it's been exceptionally cold lately. Got to get back on my weekly start-up routine.
I literally just did the same thing. Glad it fired right up!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
OR..... buy some ultra compacitors & build yourself a boostpac
OR go to sears & get yourself a diehard platinum. - mine starts in -54°(i dont' want to talk about it )---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
enjoy the sun!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
roads are clear now???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
heavy rains in this part too. april showers suck lol. anxious to see this back on teh road---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
