Ordered new axle seals, but also started looking at some upgrade goodies. I messaged ferdi about the spherical bearings, hopefully I can still get a set made. Besides that, it looks like I can use 1998-2005 Miata adjustable front sway bar endlinks (already have the AWR 21.5mm rear sway bar and adjustable endlinks). I might go with AWR again for the fronts unless I find something else.
Since Energy Suspension doesn't list anything for these cars, I found out that the 1979-1985 RX-7 also had a 23mm (0.906") front sway bar (same diameter as the BH). They look the same in the picture, so I'm going to take the risk and try them out. Going with the black ones since they're apparently treated with graphite for lubrication. They're only around $12 from Autozone, so not a huge loss if they don't work. If all this works, I think all that's left would be the rear suspension links and related bushings.
Trying to open up some upgrade opportunities for other BH owners. I'll let everyone know how this works out.
