Jacked jack shaft.
    Jacked jack shaft.
    My jack shaft is jacked. How can I freshen it up?
    Remove dust seal, clean bearing, grease it up, reassemble? Will the bearing need to be hammered/pressed in or anything like that? What am I looking at here?
    I called a couple of transmission shops in the area and none of them were willing to service axles. They said they just buy them remanufactured.
    Is that an intermediate shaft, Both of the axles I've replaced with remanufactured ones. It's only around $60 a piece. But if that's is an intermediate shaft (the center axle to help with torque steer) I'm not sure if they sell them.
    1992 Mazda Protege LX w/Primer spots
    Plus new
    1991 Mazda Protege LX w/138,000mi
      Yes it is an intermediate shaft, and no they don't sell them.
      See, I bought NEW axles and I fugred I might as well have the intermediate shaft serviced..... I didn't know it was dirty like that until yesterday when I took it out of the box (got it from a yard on car-part).
        bump for help
          I haven't. And I haven't been to the garage today... busy with school. I'll check tomorrow.
          In the mean time.... anyone ever taken one of those apart?
            yeah
              Originally posted by Intruder
              yeah
              yeah what?
              Almost there
              jdm tails... check
              jdm bumper... check
              ms lip... check
              ms grill... check
              ms sideskirts... check
              ms rear skirts... check
              ms spoiler... check
              ms struts... check
              Still trying for a bp swap..:
                exactly
                  Instead of calling I decided to drop by a transmission shop and see if they could tell me anything about the intermediate shaft.
                  The guy looked at it and said the bearing was fine. He told me to just use some brake cleaner and clean the shaft/splines. And that is what I'm going to do. Easy enough.
                    ...clean the shaft
                    haha
                    Almost there
                    jdm tails... check
                    jdm bumper... check
                    ms lip... check
                    ms grill... check
                    ms spoiler... check
                    ms struts... check
                      lol
                      BTW, your harness was supposed to come in today. Got it already?
                        lol
                        it came late this evening.
                        Almost there
                        jdm tails... check
                        jdm bumper... check
                        ms lip... check
                        ms grill... check
                        ms spoiler... check
                        ms struts... check
                          You have to get the replacement bearing from the Dealer, then get that one pressed out, and press the other one in ...
                          Dealer can get you the part number from the schematics.
                          photo album|photo album 2 (pbase)
                          dbest1a AT yahoo DOT com
                            I have those same schematics and so far I've been very effective in getting the part numbers myself. That won't be necessary though. The joint shaft is fine. All I had to do was clean it.
