you should be okay with it. unless you plan on running boost set at 30psi.lol, j/k!
it looks fine. the product makers look to be fel pro and beck arnley, some okay names with replacement parts.
Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
