Opinions Needed Please
    is a gasket kit like this worth my while? or should I be getting this sort of thing from the stealership? any imput is welcome
    ebay gasket set
    you should be okay with it. unless you plan on running boost set at 30psi.lol, j/k!
    it looks fine. the product makers look to be fel pro and beck arnley, some okay names with replacement parts.
    Almost there
    jdm tails... check
    jdm bumper... check
    ms lip... check
    ms grill... check
    ms sideskirts... check
    ms rear skirts... check
    ms spoiler... check
    ms struts... check
    Still trying for a bp swap..:
      thank you.. i don't plan to be boosting that high... but boost is def in the future
        You should have no problems with boost since the protege uses MLS gaskets. The price isn't that bad either.
        I know it's spelled protege! I just can't change it. Deal with it!
          any work i do i've always used OEM gaskets... for piece of mind
          never had a problem yet
            I've always used aftermarket and never had a problem there either.
