I have a 1995 1.5 and it is leaking antifreeze into the third cylinder. I've gone threw two head gaskets and I had the head shaved but it still leaks. It doesnt look at all like the block is crack. If anyone would know what the hell is wrong it would be greatly appreciated.
bad motor
If you had it shaved at a shop that can't do MLS gasket surfaces then that would cause leaks. Also a slim but possible cause is the idle air control valve has coolant running through it and if the gasket leaks then your engine will suck in coolant, but that would show coolant in all the cylinders.Last edited by Project Protoge; 03-02-2006, 07:35 PM.
