I did this yesterday and was very pleased with the results. Just out of curiousity since my idle was getting rough I figured I would clean the maf sensor and instantly afterwards the idle returned to a steady smooth idle. The maf sensor wasn't visibly dirty but it definately solved my problem. Also the throttle response is crisper. I just bought a can of CRC Maf sensor cleaner at schucks unhooked the Maf like it says to do and sprayed it down. Wait for it to dry and hook up the hoses and your done. I recomend this for everyone.
Clean your MAF sensor
Yeah what he said.
Mods:
The air filter helps, but ever notice if you have oil on the inside of your intake tube? it will reach the MAF...plus there are very small particles that still make it through the filter, these can sit on the MAF wire, and mess with its readings
Mods:
JDM Headlights + Corners
JDM Tailights
1st Gen LX Black Wheels
Shaved Side Mouldings
Cone Filter
E-Bay front strut bar
Originally posted by JZProwlerThe air filter helps, but ever notice if you have oil on the inside of your intake tube? it will reach the MAF...
I haven't looked in there lately, but the MAF and the upper half of the airbox looked pretty clean last time I did. However, the throttle body was black on the inside before I cleaned it out last night.
Haha, yea I forgot one of my intake valves is bad....so it still pushes it past that tube sometimes, my mistake.
Also, you can just use rubbing alcohol/isopropyl alcohol if you want, instead of spraying it with that cleaner, its all I do once in a while.
Mods:
JDM Tailights
Cone Filter
