Looseness in tranny
    Looseness in tranny
    I have the BP with 5 speed tranny, and it feels loose... when I let go of the clutch, it's doesn't grip hard, its got a loose in it... is there something I can tighten?
    Are you sure its tranny? Maybe your engine mounts are dying... its the same feeling... and there arent things you can just "tighten" in a tranny
    One day you are born,
    The next big milestone
    you discover go zoom-zoom
    you can't get enough!
    Remember, when someone annoys you, it takes 42 muscles in your face to frown, BUT, it only takes 4 muscles to extend your arm and bitch-slap that mother@#?!&! upside the head!!!
    This car refuses to die! By TheMAN
      ok, probably engine mounts, makes sense (stupid me).... how much do those go for usually? is it easy to self install?
        depends how hard you shift
        if you have some mechanic skills you could do it... but if you dont have skills i wouldn`t recommend it
          sounds like your clutch. how many miles on the car? when was the last time the clutch was replaced? are you throwing a check engine light(CEL)?
          Almost there
          jdm tails... check
          jdm bumper... check
          ms lip... check
          ms grill... check
          ms sideskirts... check
          ms rear skirts... check
          ms spoiler... check
          ms struts... check
          Still trying for a bp swap..:
            cltuch never changed, just hit 210000km, i can be hard sometimes, no cel.
              At that milage, it could be both. The front mount is real easy. The rear mount on the other hand is a little bit more of a pain. If you are gonna install a new clutch, I would just replace the mounts at the same time.
              97 protege dx few mods
              94 escort lx heavily modded
                thanx, I'll have it checked... gotta change my windshield anyway, rock hit it saturday and this morning, the crack extended midway thru windshield...
                at least my semester is finishing thursday...
