I have the BP with 5 speed tranny, and it feels loose... when I let go of the clutch, it's doesn't grip hard, its got a loose in it... is there something I can tighten?
Looseness in tranny
Are you sure its tranny? Maybe your engine mounts are dying... its the same feeling... and there arent things you can just "tighten" in a trannyOne day you are born,
The next big milestone
you discover go zoom-zoom
you can't get enough!
Remember, when someone annoys you, it takes 42 muscles in your face to frown, BUT, it only takes 4 muscles to extend your arm and bitch-slap that mother@#?!&! upside the head!!!
This car refuses to die! By TheMAN
depends how hard you shift
if you have some mechanic skills you could do it... but if you dont have skills i wouldn`t recommend itOne day you are born,
sounds like your clutch. how many miles on the car? when was the last time the clutch was replaced? are you throwing a check engine light(CEL)?Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
