i was thinking bout turboing my car but i havent never heard of anyone turboing the 1.5 motor i was wondering if it was possible and if it was what kind of turbo would you recomend
can you turbo the 1.5 engine?
a GT big 60.Beater=/= Sleeper
Originally posted by phildaddyi was thinking bout turboing my car but i havent never heard of anyone turboing the 1.5 motor i was wondering if it was possible and if it was what kind of turbo would you recomendAlmost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
yes you can but you have to TWIN turbo it. and you need a supercharger.
and 2 intercoolers.Beater=/= Sleeper
I dunno strutman managed to do it.
kindaBeater=/= Sleeper
yea it's not too hard to cut some pipes, weld stuff up and make sure you're lines are right...
i will say, don't go junkyard like i did... that's why im having so many problems, and it was my first ever turbo setup so i did make many mistakes.
ask questions of myself, 98b and project protoge since we are the three originals on here to do it in some form or another, i'd say that 98 and i followed the coattails of project pro tho... there was some other guy that did it but took his kit off since he had probs, my setup still isn't reliable yet... we'll see
prepare for down time, money, and again... LOTS OF QUESTIONS FROM OTHERS WHO HAVE DONE IT BEFORE YOU! namely, us three... honda guys will tell you different things, mustang guys will tell you others... they're different engines with different MAF or no MAF setups and all that... ask us here on the boards and pay no mind to the people giving you joking comments... if you want to do it, you can... time, effort, knowledge, and money... gather your resources... if you need help, pm me...
you can turbo any engine the question is whether or not its worth it.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
hey guys, just noticed this thread, and I just had a thought... might not be much help, but...
I have a 2000 pro, with the 1.6l ZM... not quite the same as the LZ 1.5l, but the heads interchange, that I'm sure of... so if the heads interchange, that means manifolds bolt up... so anyone thought of using a 1.6l turbo kit on that 1.5l? I might be way off, I've actually never seen a second gen under the hood... not too many of those around here... Mazda Canada was having some issues in those years, and distribution of the protege was not up to par.. not many on the roads here in Mtl from the second gen. and I don't know anyone who owns one.
the manifold flanges are completly diffrent.
and your bore is 2-3mm(iirc) over ours.
the DOHC b6 is a better option for us.
but apath/poverty makes it easier to ghetto rig something.Beater=/= Sleeper
Depends what you're looking for. A turbo BP will cost more than a turbo Z5 if you're doing both from scratch because you'll be doing all the same stuff, plus an engine swap. But you will get more out of it, and sourcing performance parts will be a lot easier. Plus it's been done many times before.
