ok, my car hasn't boiled over for 6 months since i got a new water pump, thermo, radiator, and flushed until i recently added water wetter, now if boiling over but my temp gauge stays is the normal position, and i know it works cuz when it would over heat before if went up real high... ? any ideas?
car boiling over AFTER adding water wetter
Did you get a new rad cap?... or maybe you have a blockage somewhere.
Does your rad fan kick in when it's suppose to?
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
Once it's warmed up, unplug the fans and put your hands on as much of the radiator as you can. If you feel hot and cold spots, you have a clogged rad and the flush dislodged chunks, one of which may be blocking a gallery. Water wetter won't lower the boiling point, nor will it make a car overheat so something else is going on. *If* your temp guage is working properly (just cuz it was before don't mean it is now), then it isn't boiling over. It's just leaking. If it's from around the cap, either the cap is trash or it isn't tightened down properly. If it's leaking a lot, if you pull the cap and you have bubbles coming out like Old Faithful when it's not even warmed up yet, then you have a dead head gasket.Last edited by jay; 07-16-2009, 02:40 PM.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
well this is what i did, i got it warmed up, took rad cap off and its fine, its not coming out at all.. and i did the fan thingy and its warmish all around, i also know the pumps working cuz i can see it flowing.. i think maybe i just shouldnt of added it, maybe it did more harm then good but it seems fine now, no boiling over or nuttin.
Where was it boiling over from?'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
