Hey everyone, I picked up a 1998 ProDX 1.5 DOHC for my winter beater this year... drove it home last night, then started to clean it and remove all the hack-job stereo and fog light wiring.
Here's some info:
- removed all amp/sub wiring junk from the interior and engine bay
- removed "aftermarket" fog light wiring circuit
- washed down the engine bay with degreaser and power washer
- removed a curious splice from a wire leading into the fuse box in the kick panel (*see below)
- cleaned some interior
- power washed the exterior
* The wire I was talking about was spliced into a black wire with silver stripe which ran into the lower part of the fuse box. It was a 16ga black wire which I traced to the engine bay. It was spliced into one of the O2 sensors (wtf?). I did not reconnect this splice yet because it really should have no effect on the engine starting, right?
My concern now is that I cannot hear the fuel pump "priming" when I turn the key on. Is this car supposed to do that?
The engine does crank, I get spark (it will sputter when I spray starting fluid in the intake), but I do not get fuel. I cannot smell fuel after cranking the engine a lot, and the plugs are dry.
I checked all the fuses in both fuse panels and found no blown ones. I don't have a legend for the fuse panel in the interior, so I don't know which one affects the fuel pump circuit anyway. There is no visible inline fuse in the fuel pump harness underneath the rear seat.
ANY SUGGESTIONS? Thanks!
Here's some info:
