I guess if you cannot do it then it becomes an issue of whether the expense would be worth it or not. In my case my 97's EGR passages were completely clogged from the actual EGR itself all the way into the manifold where the port allows exhaust gases to enter the manifold. I ended up getting another manifold from the JY and spent a few days soaking and cleaning that one out and ensuring the passages were clean before I installed that. I can't imagine how much labor cost you might be looking at for this.
The danger is that by leaving it this way you might cause some engine damage in the long term as exhaust gases are recirculated into the combustion chamber to lower combustion temperatures (yes, it sounds odd but it's the introduction of gases lacking oxygen which cause lower combustion temps). The main goal of EGR is to lower NOx production, but, also the cooler temps help prevent pre-ignition and pinging (which can destroy your engine). Pre-ignition is caused by hot spots inside the cylinder which cause the gas/air mixture to ignite independently from the spark plug...the pinging sound you might hear is from the flame igniting the gas and the subsequent combustion slamming down on your pistons.
So, in short, there is a small risk of engine damage long-term if you don't fix the problem, but, the overall main goal of EGR is to reduce the pollution which causes acid rain.
