My wife and I have recently traded our Dodge truck for fuel reasons. Losing 8 cylinders makes a big difference. We took a 98 Mazda Protege with a 1.5 for trade. When we test drove the car, the check engine light was on. The people that traded us the car told us that it could be a little hard to start sometimes when the engine was cold. Well, to sum it up, we killed the battery in it trying to start it. When we did get it started, we took it to Advance Auto to have the codes read. We got 2 codes. One for the TPS sensor and one for cylinder 3 misfire. The person we got the car from told us in advance that it needed a TPS sensor. We replaced the sensor and have had an awful time since. The car will not start with out jumper cable life support from another vehicle because it will kill the battery trying. Eventually it will start.
Here's what I know so far.
I am getting fuel to the fuel rail and to the injectors.
I am getting spark across all 4 cylinders.
The person we got it from showed me the receipt where he had the following installed on it within the last 6 months.
New timing belt, water pump, fuel filter, fuel pump, distributor cap, plug wires, plugs, and a starter.
I also dropped new plugs in it when I put the TPS sensor in.
I played around with the distributor today to see if I could get it to start but it didn't seem to help. It took about 30 minutes of trying to start it every few minutes before the engine would run under it's own power. The engine seems to shake a lot while it idles like there is a misfire. Any ideas? I've seen someone post the exact same problem on a different forum with no replies.
Oh and BTW, this is my second protege! My first one was a 95! I sold it about 7 years ago.
Is it possible that when the timing belt was changed that the cams and crank were not aligned properly?
Any ideas would be greatly appreciated as we can't wait to get this little gas saver on the road!!!
