For a few months now I've been having a starting issue with my 1998 Protege. When I first start it, it fires up and runs perfect, but if I leave it somewhere for around an hour and go to start it, it will either start and immediately stall, or it will spit and sputter, then stall. On second crank it starts right up and runs fine, like any car would the first time.
From what I've read, these are symptoms of a bad Fuel Pressure Regulator or an Engine Coolant Temperature Sensor, but I'm not 100% certain.
If anyone has had a similar issue, and knows what it is, I would be greatly appreciative if you could help me out.
