Ok i have a cone filter on the end of my intake hose and i just took it off and cleaned it out and put it on an dnow when i start the car it is rough and dies. whats up with that?
Help!
What did you clean it with? If it was cleaner did you let it dry out before puting it back on? Did you unplug the mass air flow to take it apart? If so make sure its plugged back up or even try cleaning the mass air flow out with carb cleaner.
I mean im not sure what was taken apart but just check to see that it is all put back together right and check for loose connectors on the tube or even a vaccum leak it could even be.
