Im doin an oil change and have been kinda thinkin about something. If i was to get a more viscous oil, would that potentially increase engine performance? I have 125k miles on my engine and just want to know what is best for my car. I change the oil regularly around 4000 miles.
oil
get the specified grade oil. a more viscous oil would degrade performance if anything (if you are talking about hp/tq)Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
redline or mobil1 or royal purple.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
or if you dont want to run a synthetic, ive had good luck with normal valvoline dino oil.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Get the cheapest namebrand and do it every 3000Beater=/= Sleeper
i had odd luck with castrol gtx... my car burned a lot of oil (like smoking on startup) with it. switched to valvoline and it hasnt done it since...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yeah i use not the cheapest brand but just do it more frequently.
Mods:
Use royal purple if your looking for a hp increase plus great protect. I went to a testing of different oils. Royal Purple was off the charts compared to the other leading synthetics. It was a bearing test with a 250 lbs torque wrench. Most oils crapped out before it would reach 250, not royal purple.Mx3 RS,BP-turbo
http://www.cardomain.com/ride/2628805
not pennz whatever you run not penz!!!!!mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
