Tranny won't change gears and NEED FUSE BOX DIAGRAM
shift lock switch!!!! or brake switch. not too familiar but one of those is the problem. its not i repeat not a problem with the tranny its all in the shifter. look for a lil cap that you never knew what was for before near the shifter of something that even says shift lock. take off that cover and push the button inside it.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
Originally posted by escortkid View Postshift lock switch!!!! or brake switch. not too familiar but one of those is the problem. its not i repeat not a problem with the tranny its all in the shifter. look for a lil cap that you never knew what was for before near the shifter of something that even says shift lock. take off that cover and push the button inside it.
