Ok, bought the car a few weeks ago. 98 LX 90K 5spd stock.
Ran like a friggin top 360 miles home, 38mpg averaging 70-80 mph
I decided to power wash the engine bay the next day.
I was pretty aggressive with the engine degreaser and the hose.
I ran it ~12 miles immediately after washing it to make sure it got nice and warm. Parked for an hour or two, then drove another 6-8 miles.
Parked it for about 8 hours and then got back in it. Within a mile it was running like crap. Felt like it was missing like crazy, flashing CEL, big power loss at more than 25% throttle. The car idled fine at that point, low rpms though ~400 on the tach, but smooth as butter.
Change the plugs and the car ran really well.....for about 20 miles.
Then the CEL came back and the same power loss.
Reset the ECU, cleaned the MAF, cleaned the TB, checked vac lines, seafoam in the gas, oil, and intake and replaced the cap and wire wheeled the rotor. Checked the new plugs and they still looked good. The idle adjusted itself after all this back to ~900. Car ran SUPER good......for about 20 miles.
Reset the ECU, pulled the IAC out. (Which by the way is very easy to take off and clean and there are NOT a lot of little parts in there that will fly all over.) I cleaned the valve and then reinstalled. I also pulled the plugs at that point and the #4 was fouled somethin fierce. The others looked OK.
The car instantly ran worse than ever. MAJOR power loss, instant blinking CEL, very rough idle (which was never an issue before) and at one point while turning the car around the engine held 3000 rpm almost as if the throttle was stuck open.
now it's pretty much un drivable. The 2 times I checked the DTC it was the same P0505.
The wiring harness and vac lines look beautiful, the intake pipe looks fine, there are no obvious defects on this car.
Where do I do from here?
Sourcing a used IAC is looking to be a little bit of a bitch. They are not the same as 95-96....new ones are at a min $200. Even if I do get one that doesn't mean it'll fix the problem.
I'm going to try and change the plug wires next, that #4 wire never felt like it was on very snug anyway.
any suggestions and guidance is appreciated.
if anybody has an IAC or even an whole TB assembly for sale let me know.
thanks
thanks
