My car was in an accident before i bought it and the airbags deployed. I've been driving it around like that for a while and I finally got both passenger and drivers airbags. Where is the airbag module located? I did some research and not replacing the module will result and the bags not deploying when you need them if you were to get into an accident. So now I need to get the module also.
Air bag module
Not sure where the module is. But maybe following the bright yellow wire connected to the passenger side air bag will lead you to it?
Edit: Do you mean the Air Bag Assembly Module or the Air Bag Sensor Unit? The Sensor Unit, part number B16A-57-K30A (1996-1998) or BH2K-57K30 (1995), is located on the floor under the HVAC assembly under the center of the dashboard.Last edited by irishkev90; 02-09-2012, 10:30 PM.
