Hey guys i have had this problem for a while. I cleaned the throttle body, the pcv valve, and cleaned the egr. But it seems that I put the egr valve back in wrong. could this be the issue? What else could it be?
Low rpm while idle in drive but when in neutral rpms high?
How did you install the EGR incorrectly? Any pictures? I bet that's the issue, otherwise I'd unplug the Idle Air Control valve and see if your idle changes.-Jack
