wow sounds like you're more patient than I'd be lol. Glad you're making progress man
Jeffs MSP GTR Build
well now im in a chicken and egg scenerio
The sounds I had been hearing from the drivetrain got progressively worse. Oddly enough most of the noise/vibration was coming from the front left.
I figured the axles were fubar from all the changes I have been making to the engine / trans mounts over the last few weeks.
SO I parked the car and grudgingly went back to my Chevy Malibu for the DD.
I figured I would check things out from the ground up so I jacked up the car and began removing the control arms for inspection and when I went to loosen the ball joints free I found that the pinch pins on either side holding the balljoints were broken and just spinning freely (installed these just a few months ago, thinking the size MAY have possibly been off by like a 1/2 mm as they were not oem pinch pins or bolts whatever they are called and maybe that contributed to excessive play causing them to break).
Then I looked over at my front right wheel and noticed that it was on a crazy jdm slant. like the reverse of a typical hella flush crazy negative camber look. Upon further inspection the wheel bearing was holding together by a thread.
so the front right wheel bearing went.
So now I am here trying to think about what caused what to break.
I am over 240,000km and this was the original wheel bearing on that side (front went out at 100,000km oddly enough). So maybe nature is just playing its course and it simply wore out.
The good news is that once I removed the wheel nut the axle did not at all seemed overly stressed and could easily move in and out of the wheel assembly. From the look of the drivetrain from up top I was under the impression the axle was in a position that resulted in it being pushed into the wheel assembly too far do to the drivetrain positioning of the new mounts, but both axles seem to be in great shape and dont show any signs of worn out CVs which is great news for the oem mount setup.
I guess now I am just going to try and grab some oem ball joint push bolts/pin things and see if I can find an entire used wheel assembly locally to quicken the process. We will see how it turns out. Hoping the bad wheel bearing was throwing off the alignment and causing the noises I have been experiencing from the front left, but that seems a little too good to be true right nowLast edited by vtec-this; 09-26-2012, 08:53 PM.
S197 Mustang GT Convertible The New DD. (Ford Racing 3.73/JLT CAI/SCT SF3 Tuner/Ford Racing Exhaust)
2009 Nissan Rogue SL AWD Maximus Tractionous Wifeymobilious
Previous ~ 235whp 1.8 BP Powered 2003 MazdaSpeed Protege ~ - Sold
well i just got the new wheel bearing so we will see how it turns out.
i've had bad wheel bearings throw off my alignment so much it chewed up tires in under an oil change. so anything is possible.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
new bosch K/O bov and got a smaller tach. car is almost back together
car is driving like new.
thanks to thuzil for the wheel assembly.
new bosch style bov is great. quiet under normal driving, zero surging. very nice for DD.Last edited by vtec-this; 10-07-2012, 07:33 PM.
awesome man! Glad you figured out your problem! I love the molded steering column cover though...wish mine was more like that lol.
Anymore info on that bypass valve? Price? Adjustable?-Jack
New tie rod ends, new control arms, new wheel assembly, new strut tops mounts and the new bov its been a busy week.
wow lol good deal then man!
I don't know much about the BJ chassis, but what strut mounts are those? They look almost solid in design.
Also trying to get a meet going in London next saturday (13th) you should try to come out! Would love to see the car-Jack
Heres the current mod list:
Engine modifications
1.8 BP Swap From 91 EGT
T3/T4 0.60/0.63 Turbocharger
GTX Exhaust Manifold
T4 Adaptor Plate
3" ID Downpipe
3" Exhaust
Stock MSP muffler
3" Ovalized Intake
2.5" Mandrel Bent Intercooler Piping
Front Mount Intercooler
VAF Deleted
Bosch Style BOV
RX-7 550cc Injectors
MSD Blaster2 Coil
Bosch Spark Plug Wires
Lex's PnP MegaSquirt ECU with 4 Bar MAP Sensor Launch Control and Flat Shift Add Ons
Blitz SBC-ID EBC
Innovate LC-1 Wideband o2
Down Pipe Wrapped
A/C Delete
P/S Delete
SS Oil Feed/Drain Lines
Protege5 Radiator Swap
Custom Coolant Hoses
Drivetrain Modifications
1.6 Bosch Passenger Side liquid filled mount
2.0FSDE drivers side top trans mount and plate modded to fit Escort GT trans bolt pattern
Modified 1st gen crossmember
Solid filled front and rear 1st gen lower trans mounts
Clutchmaster 6-Puck Clutch
Stock MSP shifter and linkage
Suspension Modifications
Front under car brace deleted
Brakes
OEM MazdaSpeed F + R with upgraded pads
Interior Modifications
Blitz SBC-ID EBC Controller
Replaced stock Mats with light diamond plate style mats
Steering wheel mounted tach
Stereo
Rear Subwoofer + tray deleted
Rear door speakers deleted
Exterior Modifications
JDM Famillia Badge
Wheels/Tires
Mazda3 GT Wheels for DD and Stock MSP Wheels currently awaiting track tiresLast edited by vtec-this; 10-13-2012, 11:11 PM.
also the issues with the oem mount setup seem to be solved.
i ended up slotting the drivers side top trans mount, and slotting/enlarging the holes for the lower mounts in the cross member so that I could straighten out the engine a bit. I am not getting and drivetrain noise anymore, however it does seem that the passenger side is a bit higher than the drivers side (around 1.5cm higher when comparing the distance between axle and the frame rail) but it does not appear to be an issue at this point.
everything is going good
Glad to see it's working out for you. Time will tell though.. We'll be doing Rusty323's pro with the straight oem setup here soon too.
HPLogic Mustang Dyno @ 15psi on MS1 v3 226 whp / 195 ft-lb [HD Video]
Soon to be powered by a Precision snail on crack...
Add me on more pictures of my projects can be found there.
hey jeff seen you on airport rd the other day, lol car sounds smexyyy95 Escort GT
-4/2/1 pacesetter header
-2.25" catback/vibrant resontor/muffer
-full cai/k-code vaf
-coilover sleeves on kyb gr2's
-15x7.5" +20ET konig roller/195/50/15 tires
-mx3 seats/console/carpet
-carbon fiber hood
more to come...
