your pad isn't contacting at the bottom. I'd replace both on that end of the car in order to get proper and even wear
Keith's '02 Protege ES Worklog
1988 Mercury Tracer. (aka Ford Laser)
Thats not to bad then. But the problem one should be replaced asap1988 Mercury Tracer. (aka Ford Laser)
Decided to tackle the pesky caliper today.
Jacked her up and took the wheel off, I had to pound the caliper off the rotor with a hammer
Then I applied liberal amounts of caliper grease to the piston, pumped the brakes a few times pushing the piston back in between times. Then put the rotor back on, and this time it fit right over the rotor unlike last time where i had to force it on a bit.
Took her for a ride, and voila! Normal brake pressure :D :D :D
Now Im just going to have uneven rotor/pad wear which probably isnt that good, but considering I just replaced the front pads and rotors in December, Im not about to do it again.
Couple pics I took of the parking lot wrenching
seriously beefy endlinks!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Moogs?1988 Mercury Tracer. (aka Ford Laser)
thats what I replaced the link kit with on the front sway link. I lowered the car last week, so I just need some free time to install the backs.1988 Mercury Tracer. (aka Ford Laser)
tools are everything. Tools bring you closer to your car.1988 Mercury Tracer. (aka Ford Laser)
and at the other end of the spectrum, having your tools stolen pulls you away. i hate when it happens, even if its just a couple of small things.loves BGs too much for his own good...
