It's not all thaaat bad. Basically a rip off of the GTR spoiler. I like it.. Downside is the hatch is garbage without now. A good highway trip should allow me to determine whether or not it's going to be an improvement or a problem. Need to remove the tint while I have it out
Started messing with the exhaust a little bit tonight. It looks like at this point that my stuff from the egt will work without much work. So far it looks like I'll only need to take about 4" from the very rear between the muffler and the subframe section. I may need to lengthen it up front around 4" when I go to redo my downpipe. Not bad.. less work makes me happy! Will be ordering some new Tokico blues / Tokico springs for it. Need to redo the braking system completely.. Need to pick up a probe/626 subframe and lca's. The list goes on. Lots more work to come
Old pics of my exhaust. zx2 trubendz 2.5" kit thats slightly modified.
After fussing with the exhaust some, I'm leaning towards getting a fuel cell for it now. I'd likely end up having to do it when I start doing the awd conversion anyways.
is the fuel tank that much in the way??? any pictures of the OE routing on that beast?
For a driveshaft to clear, yes. The exhaust? Not so much, but, I also need to plan ahead for said near future mods, so I'm not wasting my money while it's still FWD.
it can be semi expensive. but have you looked into oval tubing in the tighter areas of the tunnel? that'll help give you alot more clearance for the driveshaft
