That's a tight fit, looks good though.
Awd mp5
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
I had to trim the rear brake line brackets on the struts in order to be able to put the camber plates all the way inward. Why? Because it was hitting the inside of the wheel well on the frame rail.
I'm probably going to have to roll the rear fenders in order to prevent rubbing.
I want to tuck them up a little bit more but I don't think it's going to happen with the 205's and I'm not going any smaller. I gotta pull the strut and lower the height slowly to find out if rubbing is even going to be a issue. Technically it should pull in a little more as it goes lower. I can adjust the rear arms to give me more camber, but I already have more in the rear then I want. It's hard to tell from the pics. The first few pics were before I changed the positioning on the camber plates and found out about the strut hitting. It clears just fine now and really has no effect on the brake line bracket.
Something else that I have to play with now too Straight off the production line 2015 Focus SE Sport. Already started adding goodies!
Wife doesn't like manual. This one is hers.
I'm very tempted to pick one up and swap in the 6 speed from the ST
Going to look at a possible replacement for the P5 today.
Older or newer?92 Mazda MX3 GS> For sale, $1750 OBO
Sadly this project is coming to a end... I will be parting it as soon as I feel like putting prices and pulling parts. This is my new project > 2001 Audi TT Quattro 225 version.
P5 is gone!
