But is built for an NA FS engine making about 170hp, better to go the miata direction, I've heard they're like glass.
Awd mp5
Originally posted by Scorch3 View PostBut is built for an NA FS engine making about 170hp, better to go the miata direction, I've heard they're like glass.
Spent the day refurbishing this cheap poor fitting ecarboy fiberglass grille. I need to find or make a better one. This style reminds me of Honda crap.
a 2550lbs MS miata making 270 wheel has a hp/lbs of 9.8lbs per HP. the wagon (3700lbs roughly) at that same power level is 14.2lbs per HP.
a guy did this swap already in his escort gt. he was making 545+hp and got rid of the miata trans and replaced with rx-7 since it kept breaking.
thats in a lighter car so if you have big goals lik ehe did then switch to rx-7 setup like he did or its just gona break if you go to the track and get traction on a hard launch.
i like the idea of 300 flywheel with a miata trans. something tells me that would be a sweet ass setup, but how much firewall needs to get cut and where is the shifter gona end up ? close enough to use or will it be behind the center console?
i have been thinking of awd/rwd swaps alot lately as well. Seems like it would be much easier if there were sport20 rear ends locally available.Last edited by vtec-this; 04-12-2012, 10:49 AM.
I've been pretty busy lately and have yet to start plotting anything serious. I really need to get a hold of a junk Miata front subby/supension to build a custom tube frame from that suits the measurements that the BJ provides. Firewall/tunnel area will get chopped and replaced where its needed. I have a perfect example of a RWD BG conversion 45min away @ STP. The BJ isn't all that different from the BG as far as all that goes. I definitely plan on pushing the BP to 400+.. however, it's not being built for drag racing only. It will still be daily driver that's capable of handling well on the street and at the track. Obviously it's going to cost quite a bit to make happen no matter what.. so progress will be slow to get going. I'm all for input, thoughts, and theory's on the subject. Go for it!
mmmm sex-Jack
Are you planning on going all custom in the front end? What are your plans as far as spindles and steering rack? If you could get a hold of some 4WD spindles, and a rack, that might be an easy solution to get you the clearance you need while maintaining proper bump steer geometry.
More details on the yellow BG! Is it just setup for drag racing, or can the thing corner too?sigpic
1992 Familia GT-X
1988 323 GTX
2011 F150 Lariat Ecoboost
2014 Civic Touring
the yellow car is stp's drag scort"Discontent is the first necessity of progress."
If I have to go completely custom to avoid headaches, I will.. but with that being said, I'm really curious to get some measurements from the Miata front suspension.
That yellow BG would be an EGT. One of STP's shop cars. It's old news these days. These pictures were taken by lowkeygt awhile back. It's strip only and from what I've heard the steering is sketchy as hell on it. Pretty sure it's running a custom 8.8 in the rear. I need to go down there soon to talk to one of the guys about welding my manifold up.
What you should do is try and find a 6 spd miata that was in a really bad front end collision to use as a donor car. Then take the transmission, driveshaft, shifter, rear end, rear suspension, and maybe some of the front suspension if it's any good, and whatever else you want, and then part the rest of the car out, then scrap the shell. That way you don't have to buy everything seperatly, plus you can get all the little bits really easily.My family has lots of bg's!
1992 Mazda 323: Race car
Started pulling the dash a bit more to get the airbags and associated junk out. Still haven't done anything with the rain rails.. Ordering a set of "temporary" 15's for it this week. Did I already mention that I really hate the FS?
