End cost would it be cheaper to get the 1.6L Turbo from WagnerMotorsports or to drop in the FS-ZE. Both would end up about the same power wise.
Cheaper to get Turbo or FS-ZE
go with turbo. probably more torque.
i believe people were having a hard time finding the ecu's for the engine swap, therefor limiting the power potential of fs-ze.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
turbo and fs-ze making the same power? thats like apples and oranges, you cant compare a power plant to a power adder, the turbo has endless amounts of power that you can get from it, depending on how you set up your application, where-as the fs-ze will require more power adders to up its power, and i seriously doubt that the fs-ze will make as much power, or be any faster than a turbo application that is done correctly... and when/if you ever get into heavy modification, all the innerds that came with the fs-ze will become obselete and have to be replaced anyway, whereas the turbo if chosen correctly can be used forever...
i think you should go with the turbo btw lol...
you cant find the ecu from the fs-ze, so just pretend you never heard of it, just go turbo, and you will have plenty of power......HELLO MY NAME IS BEN...
186.08whp
225.94wtq
torque monster!!!!
dyno graph 8-10-and 12psi
blahblahblahblahblahblah
The turbo is easily cheaper...your F-series tranny wouldnt even bolt up to a FS-ZE engine...way too much stuff required for the swap...and check out the numbers biknman put down on his on 6lbs of boost...dyno'd at like 160hp..I guarantee the FS-ZE even with the J-spec ecu doesnt dyno that high
corksport says approx 170HP for the FS-ZE. thanks everyone for your help.
2000 White Protege LX
Sumitomo 195/60HR14
2 x Polk DB570 (5"x7")
Kenwood KDC-MP522 Head Unit
Kenwood KAC-7251 (800 W) Amp
Audiobahn AWC10T x 2 Subs
Kenwood Music Keg
Black Widow Keyless Entry
Intake- Custom SRI
Clear Corner Lights
APC Clear Tail Lights
