what mods u done for 200plus tq
to goldpro
Wagner turbo kit. (hes gone now) So you can do the same with a hiboost.
The 1.6l is a torque monster. Just about any mods give it insane torque first and very little power. Its really our intake mani holding us back . Which I intend to swap this summer. So all that torqe will finally net some power.
Some guys get 130 whp with just intake and exhaust (in europe).
So yeah to recap he was running a t25, at some 15 psi. Dont mind the pressure rating these engines take 30 and pump out 300whp on stock internals.
What IM are you swapping out your IM for? Would you be able to get your hands on one more? *wink, wink, nudge, nudge*
Originally posted by zerocoverWagner turbo kit. (hes gone now) So you can do the same with a hiboost.
I'm sure he's thinking of the e-spec ZM intake manifold with VICS dual runner system... I'm planning on doing the same... it's just hard to find those manifolds...
FYI, since you seem to be pretty newb.
the same 1.6l engine you have has a different manifold in europe (ans asia, I was told, but not sure yet). That manifold has two sets of runners, a long one and a short one. one set is always open and is mainly beneficial in low rpms. when you get higher up in the RPM band, those primary runners become less than efficient, and the second set, optimal for high rpms opens up.
that's roughly it, as well as I can explain it without getting too technical.
you need the manifold, preferably new gaskets, the VICS solenoid and a couple more things, and an RPM activated switch, check MSDignition.com for that...
it's fairly easy to rig it up... but I wouldn't attenpt it if I've never done any fairly heavy work on cars...
you can check out protegefaq.net there is some info on it there, and plenty other info about your car you can learn about.
Originally posted by Etienne View PostI'm sure he's thinking of the e-spec ZM intake manifold with VICS dual runner system... I'm planning on doing the same... it's just hard to find those manifolds...
I think when I asked that question in the previous thread, I was pretty newb when it came to IMs. I didn't know one was available to me (and the other 1.6 guys) until someone else mentioned it to me. I am also having a hard time trying to get a hold of both the IM and head from the ZL-VE. I was able to have Derrick from Corksport locate both the cams and cam gears for me as well as some other parts. He did quote me before on the manifold, but for whatever reason, he wasn't able to get his hands on it. Maybe you could try sending an e-mail his way and have some luck? Keep me updated.
Originally posted by zerocover View PostWagner turbo kit. (hes gone now) So you can do the same with a hiboost.
these threads you're reviving are over a yr old bro.1993 Protege LX-Midnight's shadow SOLD
A old thread is old
B You don't even have the same motor that ben had.Beater=/= Sleeper
