I recently moved to Texas, and I got pulled over for my expired Florida plates. I have had them renewed, the stickers are just at my patent's place in Florida. Anyways, it's come time for me to pony up and buy the car from my folks and get the title transferred.
To get a title transfer, I need to pass inspection. It's a 99 1.6L Protege DX, with 106,000 miles on it.
When I took it to the inspection place, they pulled 3 codes from it. Apparently my "Check Engine" bulb burned out and has been "on" for a while, begging me to fix something. The three codes are:
PO171-System Too Lean
PO402-EGR Excessive
PO300-Random Misfire
The repair shop I usually go to tells me that I need the following work done to fix the codes:
PO171 - New air intake hose and mass airflow meter = $40 (air intake hose) + $136 (maf) + $86 (labor) = $262
PO402 - New EGR Valve, EGR VSV, clean EGR passages = $270 (egr) + $245 (labor) = $515
PO300 - New sparks and wires - $44 (sparks, wires) + $106 (labor) = $150
Check Engine Light - Rip out dash and put in new light - $172 (labor)
Labor is $86/hr at this shop
A little bit of history too: The air intake hose had a comically large gash in it a few months ago which caused the car to idle very roughly and stall out all the time. I fixed it with a liberal dose of duct tape and it's been running like a dream ever since. Could the 3 codes be linked to that? Could these be old codes that would go away if I simply replaced the air intake?
I already called Mazda, and it's way out of warranty, even for emissions stuff. I'm going to get a second quote somewhere else a little further out of town in a cheaper neighborhood, but I'm not sure how much lower they can go with all the work that needs to be done.
I'm thinking that with the right know-how, it shouldn't be extremely hard to fix these issues. I've already found the MAF, removed it and cleaned it. I've found a source for the air hose, so I'll replace that as well. The one repair I'm more hesitant about is the EGR stuff. The printout I got from the estimate says "EGR Valve, EGR VSV, clean EGR passages"
What all doers that entail?
PO402-EGR Excessive
