Can someone tell me the enigne specs by lookin at the pics...? Thanks...
Engine Spec help...
2.0 litre inline 4, essentially the same FS engine as in the Protege. Yes, really. It's the same damn engine. The one in the picture has slightly less power, 125 hp instead of 130, and 130 lb-ft of torque instead of 135. Other than that, same thing. Specs found here: http://www.automotive.com/1998/99/me...341/index.html1995 626: daily beater, mostly stock. Future NASA racer?
Next up: Speed6 or RX-8
Originally posted by 1Mazda323Fan View Post2.0 litre inline 4, essentially the same FS engine as in the Protege. Yes, really. It's the same damn engine. The one in the picture has slightly less power, 125 hp instead of 130, and 130 lb-ft of torque instead of 135. Other than that, same thing. Specs found here: http://www.automotive.com/1998/99/me...341/index.html2002 protege ES/ header/2.5" exhaust/ CAI/ mazda speed cams(FROM JDM protege)/tein lowering springs/AWR 95 durameter motor mounts/B&M short shifter/ revised mazdaspeed limited slip differential/ exedy clutch/ fidenza light weight flywheel/ tokico struts/awr adjustable sway bar endlinks/stock wheels painted black W:riken raptor tires.
