Hello Everyone,
As an intro I have an 01 protege 1.6L, standard trans with no mods. Recently I had the head removed, machined and replaced due to stripped threads in one of the cylinders. After ~2 months of driving the car start hesitating very badly, mainly in first gear.
It runs fine when idling, however, it tends to bog down and yerk when under load such as when starting out in first gear or travelling at a low rpm in a higher gear and hitting the gas. I have had CEL's such as "lean bank" and "cylinder 2 misfire". Below is a list of my findings so far:
-switched coil packs around and CEL changed to cylinder 4 misfire, then replaced that coil pack with no avail, same CEL still comes back.
-cleaned and inspected EGR valve
-replaced cracked air intake tube
-probed MAF sensor and seems to be functioning fine
-O2 sensor 1 seems fine, voltage bouncing from 0.2 to 0.8, O2 sensor 2 stays around 0.8V for quite a while when driving(is this bad?)
-sprayed carb cleaner around intake when running, no vacuum leak there.
I'm sure there's more but i can't even recall all the things I've tried to do to fix this. Any more suggestions?
