Originally posted by mothra
View Post
Service to accompany timing belt
Originally posted by goldstar View PostHere is the proceedure for the FS-DE engine, according to both the FSM and the Engine Workshop Manual FS:Originally posted by pinkshinyalan View PostYou can get the service manual yourself for free here:
http://www.floptical.net/mazda/Originally posted by mothra View PostHi, This is nice to know, however, its for a 2002 not a 2000. Is there much difference?
ThanksOriginally posted by pinkshinyalan View PostI have no idea. I'm pretty new to these cars. If yours is a 1.8L engine, then yes, it should be the same. Might be the same for the 2.0 also, or at least similar, since as I understand it they're the same family of engines.
According to TheMAN, the FS Engine Manual can also be used to rebuild the FP-DE 1.8 L engine since the FP is essentially a destroked version of the FS with all specifications the same except for a few minor differences which do not affect timing belt replacement.
Therefore, the instructions provided in the FS manual for timing belt replacement should be the same for the 1.8 L engine.
For more information about the FS manual, go to:
Happy Motoring!Last edited by goldstar; 09-09-2010, 11:09 PM.02 DX Millenium Red - The Penultimate Driving Machine
