Found me a suitable donor at the JY today. If luck holds for me tomorrow I should be getting a matching Black Mica spoiler and fog light assembly.
Anyhow the engine that is the donor has a cork gasket between the engine and the lower oil pan (mine's rusty and I need to make a 3,000 mile trip soon so I'd just assume replace it before going). Pan literally looks to have been replaced days before hitting the yard as the oil inside is still clean. Makes me wonder why the car is here since there's no body damage.
I noticed that other Pros/Probes had gray sealant between the lower pan and engine.
Is there any harm in using a new cork gasket, or, should I get me some gray RTV to use on mine?
Also, anyone know offhand if there's a particular order to torquing the bolts once I have the pan in place? TIA.
