I have an 03 protege lx that has developed a gas leak. I found the access panel under the rear seat and found the source of the leak is on the top tank cap where the pump goes in. Does anyone know if there's bolts that come out, or does the whole top cap spin off after I remove all of the hoses and wires? I see tiny bolts on the outside of the cap, but they are so rusted I couldn't get a tool into them. I'm not even sure if they had a head or are flat I guess. The gas is coming up into the middle of the cap, so I'm assuming I just need to replace the gasket. The rest of the tank is in pretty good shape, I don't want to spend a lot of money if I can just replace the cap or gasket. Thanks for any advice!!
Matt
Syracuse, NY
Matt
Syracuse, NY
