Hello Everyone,
I'm in the middle of the removal and replacement of my #2 and #3 Engine Mounts (Passenger Side and Lower Front Transmission)
on my 2000 ES 1.8L. I finally got the correct tools and advice from goldstar and the removal has went well except for the
passenger side AWR Mount installation.
The mount is rigid and exacting. The holes are smaller than the stock part and the fit in my opinion seems too tight. No matter which way I approach this installation the mount seems too precise (too small) and unaccommodating. If I mount the bulkhead side first and then try to mate the engine side I can't cover the distance between the mount and the two bolts on the engine.
If I mount the engine side first and then attempt to mount the bulkhead side the mount seems small. I can move the engine because I have it hoisted and a jack under the motor but I can't close the distance between the engine and the passenger side mount to get the bolts installed.
Has anyone installed the AWR Racing Passenger side engine mount, P/N: AWR-3301HMT? How did you get the mount to fit both sides such that the holes on the frame and the bulkhead/wheelwell stud mate like they're supposed to?
Do I have to loosen the #4 Engine Mount (auto transmission) to improve the ability to move my engine. I can move the engine a 1/4" easily but after that any extra movement is achieved by jerking the motor. Note, I have already loosened the #2 engine mount. Check the pictures, do you see how far the center hole is from its mate. Any ideas on how I should approach the install? How can I close the gap between these parts? The engine side bolts are not even tight in the pictures.![scratch](https://www.clubprotege.com/forum/core/images/smilies/scratchhead.gif)
![Click image for larger version
Please help, I'm a newbie Protege DIY. Thank you for all your suggestions.
