just put an intake on my 1.6 now car bogs out checked mass air still same prob any one have this happen let me know
2001 1.6 bog out help
Welcome to CP.
What intake did you use? SRI or CAI? Modifying the air intake on the 1.6 L often results in a MIL. This is frequently due to the difficulty of making a secure seal between the air pipe and the MAF sensor. Make sure the connection is absolutely air tight.
Please don't double post. I deleted your identical post on this subject which also happened to be in the wrong thread.
