The car has 140k.
The car idles roughly for the first 10 minutes of driving, and only in drive. Rpms dip coming to a stop, below 500 rom. The car will also idle irratically between 400-700 rpm. Once warmed up it gets a little better. Car has new plugs and wires. It was showing an SES for EGR which it was cleaned 3 times between 75k and 85k miles. SES light came back on but went away 20k ago. Car idles normally in park.
Other issue I have is the transmission. It began slipping at 80,000 miles, only between 2nd - 3rd gear. It seems to shift smoother if you let off the throttle slightly. It has gone 60,000 more miles and now has 140,000. I did not flush the trans for fear of making the problem worse. What could be the problem?
It has a couple issues currently that I am aware of. First is the engine mount needs to be replaced, engine shifts whrn put into drive and reverse. The other issue is the alternator is getting weak.
Any suggestions?
Any suggestions?
