I was wondering if it would be safe to make little slits or open up the area to slide the temp and gas needles thru a set of reverse gauges. I was stumped because the area right around the needles light up, so i was wondering if any cuts would break the layover...
Reverse Gauge Option
even the all indiglo gauges still lit up with a slit in the middle of them. although you can see a bit of light pierce through the slitl. That may not be the case with indiglos, I can't say for sure because I installed the reverse gauge faces without any cuts.
Then again I did go through three clusters before getting it right :ARCADE:
btw- Greg, I wanted dibs on the muffler
Originally posted by Witchdoktoreven the all indiglo gauges still lit up with a slit in the middle of them. although you can see a bit of light pierce through the slitl. That may not be the case with indiglos, I can't say for sure because I installed the reverse gauge faces without any cuts.
What muffler?
Originally posted by Special BlendWhat muffler?
don't feel bad about the needles. been there done that, 3 times over
salvage yards carry clusters for around 50-75 bucks compared to the dealersihp wanting 350ish. Only thing with a new cluster is that it will change the odomoter reading, something to keep in mind in case the car is still under warranty.
Originally posted by Witchdoktorthe infamous Proto2k green muffler (check out his sig).
2000 White Protege LX
Sumitomo 195/60HR14
2 x Polk DB570 (5"x7")
Kenwood KDC-MP522 Head Unit
Kenwood KAC-7251 (800 W) Amp
Audiobahn AWC10T x 2 Subs
Kenwood Music Keg
Black Widow Keyless Entry
Intake- Custom SRI
Clear Corner Lights
APC Clear Tail Lights
Originally posted by Proto2kYou must be typing this standing up. Because there is no way you can sit after being raped so hard.
LMFAO!!!
edit - not laughing at Brad or Special Blend, the line is just classicLast edited by Witchdoktor; 08-26-2004, 06:53 PM.
Originally posted by jnorionYou can change the gauges out of the cluster so you can keep your odometer.
http://www.msprotege.com/forum/showthread.php?t=48154
