awr headers fit the 2.0's only
best exhaust setup for 99 ES?
Originally posted by ZoomZoomH
legality of removing your cats depends on the locale you live in.
some parts of the country you can run straight pipe (no mufflers either) and no one will care, some parts won't even let you have anything that resembles an aftermarket header.
check with your local DMV for more info.
Don't ever move to Anchorage, Alaska. It is illegal to have an aftermarket exhaust02 Protege ES
thanks for all the help. As for the AWR I know it doesn't fit the 1.8. Is there one that does?My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
