On Easter Sunday my gfs car over heated on I-95. We got to our destination luckilly only a few blocks away. The coolant was bone dry. Once car cooled down enough so we could look at it, we put water in the radiator. It started leaking on the bottom. I removed the fan today and bought some of that liquid aluminum radiator sealent from pepboys. It held for about 15-20 mins then I drove around the block at 20-25 mph. The pressure caused the leak to spray again. It is a pin sized hole that sprays 1-2 feet.. very thin stream.
Does anyone know how hard it is is to remove the radiator and put in a new one? I am no mechanic. I can change my own oil, air and fuel filter. Changed my brakes, lights etc. Is it going to be removing all sorts of engine parts just to pull this bastard out, or is it free standing by a few bolts? I got the fan and the plastic piece for the air filter off above the radiator off with 4 screws. ALL ADVICE / INPUT / RECOMMENDATIONS ARE WELCOME!!
Thanks!!
Thanks!!
