front or rear bearing? i need to replace my rear bearings. but at 260k its to be expected
What did you do to your BJ?
Originally posted by proctorsprotege View PostAtlanticx how much for the rockers? Mine are lookin rough towards the rear
Sent from my Galaxy Nexus using Tapatalk
it was the front bearing for me. I didn't realize how much the bearing noise was hiding engine and tire noises.
I saw the how-to on the rear bearing, which looks doable with hand tools. "doable" in heavy quotation marks. the anti-sway bar end links I installed were supposed to be 1 hour with hand tools, it took me 2 days with an angle grinder and I still needed to bring it in to a shop 2x to finish the job.
pulled apart the drivers front caliper cleaned it to a sparkle inside the piston bore replaced the brake line & bled the hell out of that corner. (it was dragging badly)
not a fun job---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
new Optima group 35 battery installed. to replace the Exide Orbital that only lasted 36 months, just barely inside the full warranty period. probably less than that as it was crappin out on me over the winter and it was too cold for me to be bothered. one thing i wished the dealer hadn't thrown away the battery cover. the battery with the provided height adapter fits but the OEM cover wouldve given the width an even cushion for the battery tie-down to do its job. fingers crossed on the new battery
lunch:
followed this fool word for word. this did fix a sticking/hard to turn steering wheel. the instructions say to do a 2 step application. half a can, once like scotty said. then again with no power steering fluid and only 1.5 cans worth. then a final flush and steering fluid fill. I might save the other half a can for another time, and do the goldstar method of manually exchanging the fluid in a couple weeks.
5 freakin hours even WITH an impact wrench!
i swear the last time did front rotors/pads it was 1.5 hours from wrench on to wrench off.
and i think my right caliper is stuck. i had the worst time trying to retract the piston, and during the bed it i could've swore the steering wheel pulled to the right. but i couldn't duplicate it and the car stayed straight.
did you bleed out the old fluid from the calipers??? if not get back in there & bleed them till you have clear fluid again---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
well! my right wheel was smokin! it was definitely seized as the car was slow and when I stopped on a hill the car didn't roll. and I seriously melted the brake grease to a white powder, and the glue holding the pre-installed shims on the pads blackened and fell off. replaced the caliper this morning, bled it, went to work. no smoke, steers straight.
yea i know I have to get back under to bleed the rest of the corners, but boy am I glad at least this chapter is over.
thats how my car was when I first got it. right caliper was siezed. once i swapped to the mazda 6 front brakes. the front left siezed. (PITA)
glad you got it sorted.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
