Steering Wheel shaking
    ok this is really getting annoying and i want to know if anybody else has had this problem. When i get to around 55-60mph my steering wheels starts to shake rapidly. i just replaced the side engine mounts with awr poly mounts and put corksport poly inserts into my front and rear mounts. so i dont know if its an alignment issue or whether the poly mounts are just putting a lot of the vibrations into the steering wheel. by the way this is all in reference to a Mazdaspeed Protege, and i have heard or MP5's with this problem too. Anybody else have this problem??
    Yeah, my DD does this too. Alignment didn't solve the problem, I suspect worn tie-rods.
    1993 Mazda Familia GTR - work log
      Could be a few things. Tie rods,bal joints,bent rim(hitting pot holes),unbalanced rims/tires. Start with the first thing and check your ball joints and tie rods. Then if those are ok go down and have your tires rebalanced.
        I have the same thing... If you have access to a spare set of wheels you might throw them on and see if it changes too. I know mine is either a wheel out of round (chrome wheels are the worst even if you've painted them), or tires need balancing.
        1988 White GTX - #1 parts
        1988 White GTX - #5 Rally car
          I bought a service contract with Firestone when I first got my car. If you have a service agreement that covers balancing and alignment, take it in and have it checked. My guess is tire balance. Most suspension problems cause shaking at all speeds, only the frequency of the shaking changes with speed. Tires are balanced for a specific speed and a lot of shops don't do a very good job. If the balancing is off and causing the shaking, you can be sure that you will have other suspension problems as well before long.
            Are your tires balanced?
              well the original weights are still on them, but i have noticed that the insides of my tires are bald. thats why i thought it was an alignment problem, maybe toe out a little. before i bought the car though it was in an accident but no frame damage was reported. my tie rod ends look fine, even the rubber bushing is in good condition. since i am selling the car and dont have anymore money to fix it i think i will just tell the new owner it might need tires and alignment. thanks for the input guys.
