I have a factory engine wiring harness for a '98 BH chassis with the 1.8 BP and auto transmission.
It is in very good condition and came out of a very well kept car that was involved in an accident. There is one connector end (I'm not sure what that connector went to) that needs to be repaired.
If you want to swap a BP into your 95-98 BH then this harness will save you alot of time making your own or a ton of money getting one from the dealer.
I'm asking $160 obo shipped in the lower 48 states.
If I get a full $160, I will include the rear O2 sensor specific to the BH 1.8. No guarantees on the sensor, but it is the correct one with the harness and rubber boot where it goes thru the floor.
I can also supply the stuff needed to maintain emissions compliance and OBD2 funcionality: ECU (BP3D), intake manifold/plenum/throttlebody/egr assembly, fuel rail and injectors, exhaust manifold w/heat shield, downpipe w/O2 sensor, front section of the cat pipe (bolts to the downpipe and makes it easy to install a cat for emissions compliance), front section of pipe after the cat with the O2 sensor bung, passenger side motor mount bracket, etc. (for additional cash, of course!).
It is easiest to email me at:
opelbits@yahoo.com
opelbits@yahoo.com
