You know the DOHC M/T TB also works on the SOHC engine just fine. It's just a little bigger bore.
indeed I do, thats what Im running right now, have been for about 6 months..you also have to port the plenum to match to actually make it worth it, which Ive done.
It kinda hurts low end tq alittle, but I feel an improvement on the highway and higher rpm's...I wanna put a B8 T/B back on to see which I like better. The sohc isnt much for high rpm anyways, lol. It was basically just to see what it would do. I sold the b8 t/b I had on ebay.
thanks for the reply, tho.
bump
I see. I used to have one but I threw it out. MX-3 guys usually have a lot of extra TBs from the sohc 1.6. You might want to try mx-3.com. I think it's the same size as the 1.8? Good luck.
iirc, the sohc b6 t/b is 50mm, the b8 is 55mm, and the bp is 60mm.
Originally posted by 1967cutlass
I probably have one, I'll look this weekend
Thanks, I was just wondering if someone on here had one before I try looking other places.
