Anyone pm me thanks
i want a mazda mx3 v6 gs shirter linkage....
a DOHC pro LX/ EGT shifter assembly will work---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Who says? Someone used an escort LX shifter on their v6 swap not a gt1993 Protege LX-Midnight's shadow SOLD
There is an mx3 with a KLZE swap in one of my junkyards. I already stripped it of most the modified parts. The shifter linkage is still there, and in decent shape. PM me if you cannot find one, I'm free to pick it up on wednesday for you if needed.Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
Originally posted by CODY004WD View PostThere is an mx3 with a KLZE swap in one of my junkyards. I already stripped it of most the modified parts. The shifter linkage is still there, and in decent shape. PM me if you cannot find one, I'm free to pick it up on wednesday for you if needed.
Originally posted by mazda323tDo you know if someone have the mx3 for sale or if can i use the shift linkage of a mx3 4cl??Original owner: 1991 Protege LX (now w/SOHC) and a few more BG's ....
The stabilizer bar is the same but the actual shift linkage whcih connects to the tranny shift shaft is offset on the V6 MX-3 by about 1/2" or so from the I4. I say this because alot of the stabilizers are wrecked i.e. the rubber isolator loses its bond to the housing and the shifter will fall throguh the floor. But you can replace it from any MX-3 or 90-94' Protege.
Just FYI.
Originally posted by 300BHPZE View PostThe stabilizer bar is the same but the actual shift linkage whcih connects to the tranny shift shaft is offset on the V6 MX-3 by about 1/2" or so from the I4. I say this because alot of the stabilizers are wrecked i.e. the rubber isolator loses its bond to the housing and the shifter will fall throguh the floor. But you can replace it from any MX-3 or 90-94' Protege.
Just FYI.
The BG Protege and MX-3 RS stabilizer bar and shift rod are exactly the same. The MX-3 GS shift rod is slightly different. That's all I'm saying.
And check the condition of the isolator rubber dealy at the bottom of the shifter in the floor. They tend to rot and fall apart and the shifter will fall through the floor. I'm also saying that.
The linkage is different between the two.. The protege linkage is about a 1/2 inch shorter. I COULD NOT bolt up the stock protege linkage to my v6 trans when I did the swap. I needed the v6 mx3 linkage. Ive seen where someone slotted the holes in the floor for the shifter but ide say just get the right stuff. THE STATIONARY PART OF THE LINKAGE WILL NOT EVEN BOLT UP ITS TOO SHORT
1992 MX-3 GS - KLZE
1997 Probe GT
Its not a BP05.... Its a BPOS... BIG PIECE OF ****
when the shifter fell through the floor on my protege , I couldnt get the stock linkage to line up.. it was about a half inch to short, so I had to rob my mx3's linkage and it fit right up. With junkyard cars u never know if its been replaced or not, especially with how crappy our linkages are. ive had that **** fall and scrape on the ground before.
1992 MX-3 GS - KLZE
1997 Probe GT
