do we know if the mx6 v6 harness works for the swap?
How - To: V6 Swap Guide
1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
Originally posted by MATT91GT View Postdo we know if the mx6 v6 harness works for the swap?"Discontent is the first necessity of progress."
boo, ok good to know1994 Escort LX Wagon
Originally posted by MD323 View Postnope its completely different than the mx3 one
i wish someone could test this out and see....
if i just didnt score a deal on everything i would get the mx6 harness to check it out.1994 Escort LX Wagon
oh a side note. what about the egr? do people keep it or block it? what would you guys recomend for me1994 Escort LX Wagon
if you have emmisions testing you will need it. But if you do not then there is no use for it your ECU does not read the fact if is working or not and will NOT put it into limp mode like many way think. you will get a cell from the selinoids being unpluged but will not effect anything what so ever. If your that concrened about smog get a cat.
in my area all they check is a visual. im not sure if they look for egr. i will have a cat because its legal.1994 Escort LX Wagon
a klde ecu would be ur best bet, BUT, whichever Maf u use with your ze your gonna have to match the Ecu with it.
u can use
mx3 gs -ecu/maf
probe/mx6/626 - v6 ecu/maf
of course the better one would be the probe/mx6/626 ecu/maf.. but if u just need something to get it running.. than u cna use the mx3 gs one aswell
k8 is from an mx-3, the 1.8v6
just go to the wreckers and grab a VAF and ECU from the same car, just test the VAF before you buy it, just the resistance and what not.
JACK.-Jack
Originally posted by jitb37 View Post*Edit*
The Mx6 LS - Probe GT V6 trannies do work with the KL swap in the protege, along with the clutch etc.
The gearign is different Top End gearing is shorter. - And the 1-2nd gears are longer. Depends on your preference neither one is better, just depends on what u want to do..
Surley fifth gear is higher then in my 00 Protege. At 80 the engine is turning 4000 RPM. One reason for me doing the swap besides the ovbious is the taller fifth gear.Got Zoom?
2000 Protege ES
