Thats how Josh's sat. He ended up cutting the spring. Just cut the top coils, all they do is sit on eachother anyways...
Bp and GTR AWD swap (MX-3)
basically I had to drill custom holes and make custom rails for the rear for strength and cause the rear rails slant up so i had to make straight rails for the rear end to bolt on.. also had to cut out the arear for the spare tire to make room... there was other cutting done and other things done to make the rear end area stronger to deal with the torque and hp that was never meant for the rear end
as to wheel gap right now i have ground controls that i will install and when i have the money i'm buying AST coil over struts (12 point dampening and height adjustable)In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
"Shut up, at least the bunnies are on fire!"
i need to come take a look @ this project you have going tim.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
dude you are welcome down anytime.... it is more fun when a friend hangs out while i'm workin on it... and anyone who helps at least gets some free alcoholIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
just got my stainless steel oversized valves in from corksport!!!! beautifulIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
Just gotta ask how much for the rear end set-up. As I want to figure out what it would cost to convert to awd.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
it cost me $900 for the rear subframe and was only missing a few parts... the new studs to bolt it on were around $15, the sheet metal to make custom rails was around $30, the other stuff i used to add support and some of the various tools i had to buy cost around another $40, my friend had a welder so i didn't have to by one of those, so i paid around a grand for the rear end set up but that isn't including the time i spent cuting, measuring and all that stuff and also not including the cost of either buying a welder or having someone weld for youIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
also i'm sandblasting and painting the rear subframe with POR-15 that will be about another $100 probably
oh don't forget you'll have to get a custom driveshaft if you want to do it right $300-$400 plus the actually trans another $200 - $300In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
carbonfiber driveshaft---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323carbonfiber driveshaft
i can't even begin to imagine how mucht that would cost or even where around here i could have it made.. that would be awesome though.. talk about saving hp lossIn the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
