Hey guys-just checking in---Beau was kind enough to drop off his unit and axles for us so we can make the necessary changes---the original axles that we mocked up with were axles we had laying around/ford axles---no one had the Toyota axles and the ones we used where a LOT longer and made the angle/CV plunge/overall arc much better/safer. These axles have a large cup before the axle start's and caused the pivot to move outboard steepening the angle. For Beau's unit/2WD guys we've already assembled it's just lengthening the mounts to the chassis and moving the pivots up. The 4WD guys will be impacted less as I hadn't made the "legs" from the bases that go to the frame. I'm off through the 5TH, but will finish up Beaus unit when we return and expedite the rest-happy holidays!
JP Motorsports BG/BF/GT4 Rear subframe production and discussion.
Originally posted by theredrocket View PostSweet! Are these for the front wheel drive guys or the all wheel drive guys?Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
Originally posted by Pashka0788 View PostDon't mean to be an ass but.. Did you read the entire title?Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
2005 Corolla
Jim, what is the distance between the newly located ttl mounting tubes?Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
2005 Corolla
Originally posted by Iantboyd View PostBe an ass all you want. Those pictured subframes are for the fwd cars. the mounting arms do not match the awd chassies.Not What you build, But HOW.
Originally posted by Pashka0788 View PostThe BG and BF both came fwd and awd...
1988 323 GT - B6T Powered
